Fusion Manufacture
DISPLAY "DRILL DEPTH" LENGTH
8 REPLIES 8
Message 1 of 9
programming2C78B
274 Views, 8 Replies
Mastercam does this, and it's very helpful. No reason Fusion can't show it in the window, if not also on the planes image on the model.
Please click "Accept Solution" if what I wrote solved your issue!
8 REPLIES 8
Message 2 of 9
bump, still want this
Message 3 of 9
I admit, I'm not sure what it is you're actually looking to have displayed, and where it would be displayed 🤔
Seth Madore
Message 4 of 9
I just realized I typod and meant to say "drill tip depth"
say you program a drill to go -1. , and enable "tip comp". Without going into View toolpath or simulating it, I don't know what the final depth of the drill is! It seems fusion thinks all drills come to a sharp, when they certainly don't in real life (usually making a hole 10-15 thou deeper than intended).
All our tap holes are called out MAX HOLE, so Id like to see that the tip length on my drill is theoretically 0.037", but I can program to -1.025 to get it very close but still be on the safe side!
Message 5 of 9
Are you using these 2 options?
LeoC
Message 6 of 9
Yes, I guess most people haven't used mcam before. This is what Im looking for programming2C78B_0-1691493773430.png
Message 7 of 9
Hi @programming2C78B,
I understand what you're saying but I program a lot, but for what reason do you want to see that value?
If your body length (length below holder) is long enough and you program with fixturing then all kind of collisions will be detected.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Consultant
Message 8 of 9
say you program a drill to go -1. , and enable "tip comp". Without going into View toolpath or simulating it, I don't know what the final depth of the drill is! It seems fusion thinks all drills come to a sharp, when they certainly don't in real life (usually making a hole 10-15 thou deeper than simulated.
Message 9 of 9
CNC_Lee
in reply to: programming2C78B
This is not currently available in Fusion.
You could however calculate the tip length using the following formula:
DTL=D/2/Tan(A/2)
Where DTL is the Drill Tip Length (in)
D is the drill diameter (in)
A is the tip angle (degrees)
To calculate a drill tip length, divide the diameter by 2, then divide again by the value of the tangent of half the tip angle.
You could also post out just the drill cycle and look at the "ZMIN" value in the tool list to see the drill's final depth.
HTH
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
