Fusion Manufacture
Display angles in radians instead of degrees.
4 REPLIES 4
banksysan
855 Views, 4 Replies
I can see how to change the units for length, but not for anything else.
How do I change the display of angles from degrees to radians?
4 REPLIES 4
daniel_lyall
in reply to: banksysan
By typing in rad when you set the dimension
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
@daniel_lyall, good afternoon!
I can't speak for the original poster, but I can create the angles with radian units, but the display is still stuck on degrees.  I'm not seeing an option to switch the displayed units from degrees to radians.  Is there a way to display the angles as radians versus degrees (regardless of what the parameter units are)?  Thanks in advance for any tips, hope all is well and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
As I said type it in.
Daniel Lyall
The Big Boss
Mach3 User
Where and How? I've tried typing 'rad' when dimensioning a drawing and it just shows the value in degrees.
