Disappearing bodies
Disappearing bodies
Can anyone tell me why the bodies in my drawing completely disappear when I go to cam? If I hover around the top level icon they all light up, but I can't see them when I'm not hovering over that drop down tab. Also if I copy and paste lest say 3 bodies off the first one, I can see all 4 bodies, but as soon as I click on a single body, they all disappear except the one I clicked.....
LibertyMachine
Does this help at all? When dealing with Components, activating them can be clumsy at first
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Thanks for your reply, I've tried over and over with the light bulbs but nothing happens. Like I said I can see them all, but as soon as I click on 1, the othe 3 disappear. When I load cam, go through the set up and everything is fine, as soon as I go to select contours to create a toolpath, all bodies disappear, and do not illuminate when you hover over them, which is difficult when your trying to pick 8 holes to be machined
LibertyMachine
Could you download the Screencast add-in and make a recording so we could see what's going on?
Seth Madore
I sure will when I get home from work! Thank you!
daniel_lyall
Try right clicking on the top of the tree and select show all components.
I have hidden all bodys by mistake, had a big panic and jeff showed me all i need to do was right click and show all components out on the modeling work spaces.
It may not be just a idea to try
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
