different and inacurate grid in CAM workspace: bug or feature ???
rumpelstielz
Message 1 of 1
rumpelstielz
hello,
just wondering what this is about. I have my grid setup and working fine in the modeling workspace:
so far so good. in the CAM workspace however, the grid is different, not only it's not the same settings as in the modeling workspace (no subdivision setting but rotation increments):
but the grid is also off, you can see here that the grid divisions don't correspond to the real measurements:
switching back to the modeling workspace and checking the grid settings again and coming back to the CAM workspace suddenly the grid is all good. just wondering if i'm missing a feature here, had this a couple of times in the last days.
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Replies (0)
