- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Did the Latest Update break In-process Stock generation?
It seems to have stopped functioning on my projects.
Is it still turned on?
There is also the visibility down here
Automatic In-process Stock generation is On.
Display In-Process Stock is on.
No matter what is regenerated or how many times the computer is restarted, Fusion does not generate the IPS. Every process in 4 different setups contains the Green check inside a dashed circle.
Simulation works if it is started from the first Process. Somehow, it calculates processes with "rest machining" despite the lack of IPS.
It was working on Friday. Now its Monday and it no longer works.
OK, it still works OK for me
What you can try is navigating here with Fusion closed and deleting all the meshes in this folder
then opening Fusion and it should trigger the IPS to regenerate
C:\Users\ftv\AppData\Local\Temp\Fusion360CAM\meshes
Replace ftv with your username
Thank you,
That seems to have worked.
