Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Designing For Tolerances
4 REPLIES 4
glencandle
247 Views, 4 Replies
Hi, I am a CNC enthusiast, teaching myself how to design parts and have them manufactured, which is lots of fun and I hope to someday transition careers using this skillset.  That said, there is one thing I still don't have a definitive answer on so I wanted to see if any pros could weigh in:
When I'm designing two parts that are meant to fit together (i.e. lid and body), how do I account for tolerances?
For example, if the shop guarantees a tolerance of +/-0.005" then do I add 0.005" to one part and subtract that amount from the other (where the dimensions fit, for example, a lid and body)?  In other words, the lid of a cylinder would be
Or should I design both parts to have the same outer/inner dimensions where they fit, and then note the tolerance in a drawing (e.g. the body tolerance would be 0" to -0.005" and the lid tolerance would be 0" to +0.005")?
Cheers.
4 REPLIES 4
seth.madore
in reply to: glencandle
Well, technically, they could machine both items and hug one side of the tolerance. The parts would meet print, but not able to be assembled (without some...persuasion).
Thus, assuming items are not meant to be an interference fit, we always want to have some measure of clearance even when the MFG'er rides a tolerance at the high/low.
Seth Madore
glencandle
in reply to: seth.madore
Hey Seth, thanks for the words of wisdom.  This makes perfect sense. Not meant for interference, but definitely want a snug fit.  Is there a rule of thumb for the amount of 'extra' you'd want to factor in, per inch (or factor), for fitted parts?
I just prototyped two parts (lid and body) that are about an inch where they fit, and added +0.005 to the inner width of the lid, and the -0.005 to the outer of the body, and the parts seem to fit perfectly.  Not sure if I just got lucky per the MFG tolerance or if I'm right on the money for this type of design.
Cheers.
leo.castellon
Engineers take a whole class on this subject. Regarding machine shops and tolerances, remember that the tighter the tolerance, the higher the cost of the part. Here is a link to an article that just touches on the subject of tolerance stacking: Best Practices of Tolerance Stacking - In The Loupe (harveyperformance.com) .
LeoC
glencandle
in reply to: leo.castellon
Hugely helpful article, thank you!!
