Fusion Manufacture
Depth Per pass problem from Fusion360 to Candle
10 REPLIES 10
Message 1 of 11
dietrichvi
370 Views, 10 Replies
Hello:
I'm very new in CNC and don't know if this will be a bit out of topic here, I really apologize if that's the case.
I'm trying to make some pieces from Aluminium and the pockets comes out well but, when I try to make a 2D contour to separate it from the plate it always goes to 3mm depth instead the 1.5mm I have specified.
Maybe I'm trying to put the depths with the wrong "tool", I'm using "Multiple depths".
In the simulation appears correct, can be it a problem with the post processor? (I use GRBL) May it be a problem between Fusion and Candle?
I will let here the file. There is a lot of "pieces" (cuts of the same piece) in the same file but the actual one with the problem (haven't check the rest of them) is the one named 'Corte Torre1' in the design part and 'CofTorre1' in the fabrication label ( the operation is '2D Contor Torre')
Tags (2)
10 REPLIES 10
Message 2 of 11
jscott6SWZG
in reply to: dietrichvi
I use candle and fusion 360.  They  2 d contour works for me with z multiple depths.
check stock to leave. -1.5 would have that effect
If simulation is good, also check simulation in nc program
also check setting z zero in candle.  Easy mistake to make
Message 3 of 11
dietrichvi
in reply to: jscott6SWZG
Stock to leave is set to zero and the simulation runs perfect (have to check it in candle yet).
Could be the "Rough final" check inside the multiple depths tab??
dietrichvi_2-1677741164137.pngThe paths you see in S is from another piece being calculated in the other tab, don't know why it shows here
Message 4 of 11
seth.madore
@dietrichvi the display of extra toolpaths from other files is a bug that pops up now and again, we have tickets to work on it. Sorry that it's present for you..
In your CofTorrex1 toolpath/setup, your 2D Contour is programmed to go down to -6mm. Is that NOT what you're looking for?
Seth Madore
Message 5 of 11
dietrichvi
in reply to: seth.madore
I don't think so, maybe I'm wrong. The total piece depth is 6mm, but I want it to be machined in steps of 1.5mm. I think the simulation is OK because, as you can see, there are 4 tool paths but in the real machine it goes down 3mm (and broke my cutter)
Message 6 of 11
seth.madore
Your first pass is being done at -1.5mm, not 3:
Where did it break, right off the bat? If your stock is in fact how you've modeled it, I would recommend turning on Stock Contours so it sends the Entry move outside of stock. However, if the stock is in fact much larger (and why you're using Tabs), I would turn off Multiple Depths and instead use the Ramp option (this is on the last tab of the toolpath). Results instead:
Seth Madore
Message 7 of 11
dietrichvi
The stock is in fact much larger. I have opted for ramp, and it worked, but I still have the same issue of the real machine going down to -3mm instead of the -1.5mm you are seeing in the simulation
Message 8 of 11
seth.madore
You're saying that the first pass is taken at -3mm instead of -1.5mm?
Seth Madore
Message 9 of 11
dietrichvi
In the real machine yes
Message 10 of 11
seth.madore
I would recommend double checking your WCS and your tool offset settings. The g-code and simulation doesn't reflect this discrepancy 🤔
Seth Madore
Message 11 of 11
dietrichvi
I tried with ramp and everything has worked perfectly. After that I tried it with another piece far longer (100 cm) so the ramp strategy didn't seem the one for that job, it ended up digging too much in the final of every path, so tried again with multiple depths and worked perfectly😕.
The only thing I can think about is that I didn't delete the old gcode before setting the max depth, and when remade the gcode it didn't export well??
Well, that will be another question for another post for sure, but this is solved.
Lots of thanks!
