Defining 3 axis machine with manual rotation of tool
info63FGM
info63FGM
Greetings
In the shop we have an old Maho machine which has 3 axis and it has manual rotation of its milling head. There is a part with a almost 30 degree surfice that requires a finish pass. I do not know how to define in Fusion360 that the milling tool is at an angle but the machine axis orintation is still aligned with the part.
I was thinking to define the end mill tool as a taper tool to circumvent the problem but maybe there is a more proper soultion to this problem.
Any advice would be much helpfull.
Replies (9)
brad_francola
Hi.  Does the mill have a coordinate rotation function?
hphanQ726A
DO YOU HAVE THE PART THAT YOU ARE CURRENTLY WORKING ON? if you can then share with us, we might help!
engineguy
@info63FGM
Are you looking to do something like the image below ? I am thinking the part will be setup to be cut in the Y direction ?
If so the try out the attached file, it is a simple 2D Contour with Multiple depths, I have done it this way because I don`t know how/if you have already removed a lot of the stock and only need a finish pass, if that is all you need then just disable the "Multiple Depths" and it wil just do a single pass at the surface, best I can do without your Model to work from.
I have set it up so that the passes are done in the Y axis so the table will move in/out on the Y, the position is moved in the X and Z to do the ;eft and right moves, so it moves to position in the X and Z, then cuts in the Y, moves again in the X and Z for the next cut in the Y and so on :slightly_smiling_face:
Hopefully it will be somewhere near to what you need, as already stated, best I can do without your Fusion f3d file.
Example file attached, open the file in Fusion and first run the Simulation and click on the "Info" tab and you will be able to follow the X/Y/Z moves, I generated some code here and it looks OK but not having the PP that you are using I am not uploading it as it is not likely to be correct for your machine :slightly_smiling_face:
hphanQ726A
We can using 3D surfacing to remove all the materials and leave only 0.010" for finishing, then we can use the "PATTERN" method to finish the angle; which allows us using smaller angle tool to finish the big angle. Hope this can help him.
info63FGM
Sorry for replying a little bit late . Sending the part together with picture of rough demonstration of the setup.
https://a360.co/3QAVAwN
engineguy
@info63FGM
OK, is the image below close to what you need ?
If so then it is just a simple 2D Contour with the "Tool Orientation" used to get the angle of the tool, I created a surface at 90 deg to the angled face to use as the Z face for the orientation to match the angle of your Head.
Modified file is attached, I used a nice big 16mm End Mill as I have no idea what tools you have :slightly_smiling_face: Feeds and speeds are up to you :slightly_smiling_face:
info63FGM
Hello
I got this error from your example
Information: Configuration: Maho Philips 432
Information: Vendor: Philips
Information: Posting intermediate data to 'C:\Users\desktop-006\Desktop\9501.nc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1250  (ANSI - Central Europe)'
Start time: Tuesday, September 13, 2022 12:28:23 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5874.5
Configuration path: C:/Users/desktop-006/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/original maho philips 432.cps
Security level: 1000
Include paths: C:/Users/desktop-006/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Monday, September 28, 2020 11:46:03 AM
Output path: C:\Users\desktop-006\Desktop\9501.nc
Checksum of intermediate NC data: 2f7c2e5b3f60357849c0ef4f75dc330d
Checksum of configuration: 1cb158792cb69e92f566e7d49811fe19
Legal: Copyright (C) 2012-2019 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.13881
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
Error at line: 381
Error in operation: '2D Contour2'
Failed while processing onSection() for record 485.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, September 13, 2022 12:28:24 PM
Post processing failed.
I am not sure because I only work with 2.5D parts but I think that your examples makes the Fusion360 thinks it is a 4 axis machine. My machine is 3 axis but the head can be rotated manually.
engineguy
@info63FGM
That`s OK, I didn`t know which Post Processor you were using, it is correct, the Tool Orientation is not supported in that PP.
So, I have removed the orientation and tested it with the Maho Phillips PP and it generates OK, just means that it cannot be simulated in Fusion but all you need is the 2D Contour and the correct setup at your machine as the tool is already at the correct angle all it has to do is go to the correct X and Z positions and then do the cut in the Y so it is down to your settings at your machine, try it now  :slightly_smiling_face:
Reckon you could do that easily at the machine control without Fusion :slightly_smiling_face: :slightly_smiling_face:
info63FGM
Yes you are right and thank you for the advice.
