DCMT tip specification.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
@akash.kamoolkar With a DCMT tip set up like this is it assumed the radius is the same on all 4 corners? It seems pretty close on the tips I'm using but wonder if it should have some fine adjustment. I prefer setting up like this so it's easy to check the depth the tool is going to move (Z axis).
I sketched up a tip with 0.2 rads all corners and get this. The actual tip measures 7.125mm but wonder if this is consistent with different radii and is this how you are calculating the width of the tip in the tool library?
Also is there any progress on making the holders correct for tips in this orientation?
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Fusion
