Fusion Manufacture
DATRON Neo postprocessor is buggy?
4 REPLIES 4
makelabASMPS
184 Views, 4 Replies
I am using the DATRON neo 4-axis machine, in this operation, the simulation goes right. The mill is centered along x and the rotary axis turns.
On the machine, however, the mill plunges into the part :
$$$ SEQUENCE_RotaryPocket5__1
Spindle On
PrePositioning X=0.9 Y=24.24075 Z=35.24651
Rapid A=0
Rapid Z=34.4 A=0
Feed=Plunge
Line Z=25.24651 A=0
Feed=Ramping
Line Y=0 Z=24.4
Feed=Cutting
Line Y=-4.23702 Z=24.02931 A=10
Line Y=-8.34529 Z=22.9285 A=20
Line Y=-12.2 Z=21.13102 A=30
Line Y=-15.68402 Z=18.69148 A=40
Line Y=-18.69148 Z=15.68402 A=50
Line Y=-21.13102 Z=12.2 A=60
Line Y=-22.9285 Z=8.34529 A=70
Line Y=-24.02931 Z=4.23702 A=80
Line Y=-24.4 Z=0 A=90
Line Y=-24.02931 Z=-4.23702 A=100
Line Y=-22.9285 Z=-8.34529 A=110
Line Y=-21.13102 Z=-12.2 A=120
I don't understand if this is a bug or not.
If I manually enable this option :
Then the NC program cannot be generated any more :
Error: You can only select either a machine in the CAM setup or use the properties to define your kinematics.
Error at line: 507
Failed while processing onOpen().
Error: Failed to invoke function 'onOpen'.
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to execute configuration.
Stop time: Friday, October 13, 2023 2:56:27 PM
Post processing failed.
4 REPLIES 4
based off your setup I'd say the rotary is along X-
It's also much better for your tool if you did deeper cuts with a smaller stepover....A part like this could probably be surfaced directly to size in wood!
Please click "Accept Solution" if what I wrote solved your issue!
CNC_Lee
in reply to: makelabASMPS
@makelabASMPS
You are getting this error because you can only select either a machine in the CAM setup or use the properties to define your kinematics. You will need to either deselect the Machine Configuration or change the configuration in the Post properties.
If the generic posts are not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Message me if I can be of further assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
AchimN
Hello @makelabASMPS
The machine definition has the TCP option enabled by default, do you know if your Datron has the RTCP feature enabled and setup correctly for your machine?
If not, then the output will not work on your machine.
You can easily turn off the TCP option in your machine definition as shown in the screenshot below:
Please let me know if that helps. Thanks
Achim.N
Principal Technology Consultant
mspodniak
Hey.
Try to see this file. I created a 4 axis instrument track and it should definitely work well. To generate toolpaths you can't have a machine simulation.
You have to have RTCP enabled otherwise the toolpaths will not be accurate and you have to aim the stock.
I'm also posting a couple of youtube links I drew from. Anyway my knowledge of DATRON is from my work. So if anything feel free to ask.
Martin
https://www.youtube.com/watch?v=NpUxAm_ybkQ&t=49
https://www.youtube.com/watch?v=kcc-vxDQD4Q&t=280s
