Cylinder sides
Cylinder sides
jpblucasborean
Message 1 of 9
Cylinder sides
jpblucasborean
Hi, new to Fusion and programming in general. I'm trying to do a side cutting profile on a cylinder using a custom tool. I drew an 18 sided polygon thinking that a simple toolpath could be made along the x-axis then rotate 20 degrees do the  same toolpath until the part completes the full 18 rotations. I'm having a difficult time doing this. Unsure of which section of the manufacture milling I'm supposed to use.
Any help is appreciated
Replies (8)
Message 2 of 9
programming2C78B
2d contour on one face, then circular pattern
we dont know what machine youre talking about. 4th axis? Live tool lathe? 3 axis hobby machine?
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 9
jpblucasborean
Sorry! Haas VF4 with a 4th axis.
Message 4 of 9
jpblucasborean
This is what I currently have but can't figure out how to 2D profile the face at 3 oclock then rotate.
Message 5 of 9
programming2C78B
Just do 2D contour along that flat, and then do a circle pattern of 18x
Message 6 of 9
jpblucasborean
Keep getting this message. I appreciate your time, thanks very much.
Message 7 of 9
jpblucasborean
Not sure what I'm doing wrong
Message 8 of 9
programming2C78B
i cant see what you selected. You only want to machine one face in this toolpath.
Message 9 of 9
a.laasW8M6T
Hi See Video and attached file
(view in My Videos)
Andrew Laas
Senior Machinist, Scott Automation
