Cylinder sides
jpblucasborean
Cylinder sides
jpblucasborean
Hi, new to Fusion and programming in general. I'm trying to do a side cutting profile on a cylinder using a custom tool. I drew an 18 sided polygon thinking that a simple toolpath could be made along the x-axis then rotate 20 degrees do the  same toolpath until the part completes the full 18 rotations. I'm having a difficult time doing this. Unsure of which section of the manufacture milling I'm supposed to use.
Any help is appreciated
Replies (8)
programming2C78B
2d contour on one face, then circular pattern
we dont know what machine youre talking about. 4th axis? Live tool lathe? 3 axis hobby machine?
Please click "Accept Solution" if what I wrote solved your issue!
jpblucasborean
Sorry! Haas VF4 with a 4th axis.
jpblucasborean
This is what I currently have but can't figure out how to 2D profile the face at 3 oclock then rotate.
programming2C78B
Just do 2D contour along that flat, and then do a circle pattern of 18x
jpblucasborean
Keep getting this message. I appreciate your time, thanks very much.
jpblucasborean
Not sure what I'm doing wrong
programming2C78B
i cant see what you selected. You only want to machine one face in this toolpath.
a.laasW8M6T
Hi See Video and attached file
