cutting notches for finger joints on CNC router
Seabird37
Seabird37
Apologies for a Noob question.  I have a simple sketch to cut 1 inch fingers in 3/8 inch ply wood.  I extruded the sketch to the plywood thickness of 9mm (approx 3/8") and then went to manufacturing.  I have try 2D Adaptive, 2D Pocket and 3D Adaptive and Pocket.  I have avoided using Contour as I wish to use this setup for cutting fingers in various lengths of ply wood (all of the same width).  I keep coming up with "No toolpaths" or it wants to cut completely around my model.  Any help and advise will be appreciated.  f3d file attached.
Richard
jhackney1972
If you cut these with the panel lying horizontal, I would use a 2D Contour using a separate sketch.  With this orientation, if will not clean out the corners.  Please check your feeds, speeds, etc. as I did not glance at these settings.  Model attached.
John Hackney, Retired
seth.madore
Try this:
Seth Madore
Seabird37
Thank you Seth.  This is exactly what I am trying to achieve.  I will give it a go when I get back from my Dr's appointment!
Richard
Seabird37
Took me a few tries to get the input as you have illustrated but after that it has work a treat! Thank you for the solution.
