Fusion Manufacture
Cutter comp
2 REPLIES 2
ruhljD9CQV
126 Views, 2 Replies
Cutter comp
When programming a contour, in the passes tab it is not showing an option for cutter comp. I need to be able to adjust for regrind endmills.
2 REPLIES 2
jhackney1972
in reply to: ruhljD9CQV
I checked this in both Fusion 360 Subscription and Personal licenses and the save dialog box appears with the settings for Cutter Compensation.  I show this in the screen captures below.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
ruhljD9CQV
in reply to: jhackney1972
Thanks, I figured it out.
