Fusion Manufacture
Custom non-insert lathe tooling
5 REPLIES 5
WillL84
160 Views, 5 Replies
How can I create a custom boring tool in F360? I want to use this solid carbide tool: https://www.mcmaster.com/3301A25/ but I can't seem to find a way to make this tool in Fusion. I have a small die with a compound radius I need to machine
Windows 11 Pro 64-bit
Inventor 2024 Pro (PDMC)
TITAN Computers C161
i7-11700K/32GB RAM/Quadro RTX A4000
5 REPLIES 5
HughesTooling
in reply to: WillL84
This might get you somewhere close. I made this for a similar bar a while ago, I've changed the angles to match your bar but you'll need to play around a bit to set the diameters. I noticed the library is a bit buggy and reset the tip angle to zero so keep an eye on that if you can't set the holder correctly.
Mark Hughes
Owner, Hughes Tooling
WillL84
in reply to: HughesTooling
I do that and I get this strange pointy thing with the holder. If I go in to the holder tab and change cutting width to 0.1in it's fine, but now the tool is way too wide and causes crashes in simulation. I had it set to 0.05in as the tool head is only .1" wide. The smallest I can go on cutting width and not get the point is 0.065"
WillL84
Ok I think I've gotten it as close as possible but it still gives collision issues in simulation. Shouldn't be a problem on the actual machine though.
HughesTooling
Try reducing the Head length and the Shank width. The total width at the tip will be 3mm/2 + 2.1 for the cutting width.
Mark Hughes
WillL84
That seemed to help, it machined just fine though with no collisions. It's be nice for F360 to have a solid tool designer as there's tons of companies with solid carbide micro boring tools out there.
