Custom Lathe Setup sheet for excel missing data
CuttingEdgeManufacturing
Hey guys, ive been working on a lathe setup sheet based off my mill sheet. all seems fine except a few values arent working quite right. I'm using the following parameters:
Feedrate : $tool.feedCuttingRel
SFM : $tool.surfaceSpeed
RPM : $tool.maximumSpindleSpeed
my bigger problem is i cant figure out what parameter is being used for the insert ANSI designation.
i just tried to guess at it:
$tool.insert.ansi
attached is a zip file of my setup sheet. hoping someone has a clue how to help with this one.
Tianq
Hello @CuttingEdgeManufacturing ,
Some of turning tool parameter names can be found through the tool dialog when you hover the mouse over the item with "Shift" key pressed. As shown in the snapshot below, is tool.insertType the one you are looking for?
Dave
Dave (Qing) Tian
no the one right above it the ansi code
Tianq
Thanks,@CuttingEdgeManufacturing . ANSI code is not a stored tool parameter that can pass through the post at the moment, instead is calculated behind the scene to be displayed.
Dave
Dave (Qing) Tian
