- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
After CAM processing my stp file and successfully running a simulation, I'm getting a failure when creating the gcode file. A file is created with the .fail extension. When I open the file, there are a few lines of gcode, then the message:!Error: Failed to post data. See log for details. I don't see any log anywhere to indicate what's the problem. Also, I've found that if I forget to save a file, if I try to process and create gcode, Fusion 360 just crashes with no indication that maybe I should have saved the file first. Rather that saving to the cloud, I'm exporting everything I do as f3d files. I was able to successfully do all this in the past, but now using the same settings, I can't successfully create the gcode file. What's up with all this? I'm processing for the Othermill pro.
Fusion
