Fusion Manufacture
Creating a sharp edge in 3-Axis milling
8 REPLIES 8
Message 1 of 9
mhzhamza
239 Views, 8 Replies
I want to make this part on a 3 axis mill , I have made the curved surface using a ball mill and morphed spiral toolpath/scallop toolpath but I am having issues machining the V sharp edge geometry , I tried using a taper end mill on a adaptive clearing toolpath and also tried using a chamfer mill  but to no avail, also the height of the blade from the tip to the root is 1.5mm.
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: mhzhamza
Please share your Fusion file here.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 9
mhzhamza
in reply to: seth.madore
Here is the file
Message 4 of 9
seth.madore
You have fillets of .5mm, are you planning on going in there with a 1mm ball endmill?
What sort of equipment do you have, and what is the application for this part? Is a razor edge needed, or is there expected polishing to be done? How many of these do you need to make?
Seth Madore
Message 5 of 9
leo.castellon
In your sample file, you have both toolpaths shown with a 6mm ball end mill. The 6mm ball would never work to get the sharp edges, it is too large, see attached pics. If I were to machine this, I would start with a 4mm ball or even a 3mm ball for the adaptive, then finish with a scallop toolpath using a 2mm ball. Or start with the bigger ball end mill for the adaptive and then make another adaptive toolpath with a slightly smaller ball end mill using rest machining then finish with a scallop toolpath with a 2mm ball or even better a 1.5mm ball. It would be best to add fillets in the sharp corners before machining because on the finishing toolpaths, you will get blemishes from the tool slamming in those corners, or possibly breaking those small end mills. To get the sharpest corners, you might have to add an additional 3d contour toolpath to get the crispest edge possible. Just my opinion.
LeoC
Message 6 of 9
seth.madore
in reply to: leo.castellon
@leo.castellon all good info, thanks for chiming in!
Seth Madore
Message 7 of 9
mhzhamza
Thank you for your reply.
Let's say we neglect the .5 fillet radius , and take into consideration the razor edge, will it be possible just by using a smaller ball end mill. I wanted to use an engraving tool on a 3d toolpath but fusion gives an invalid toolpath error.
Other than that this is just a prototype whether we can mass produce this segment is another story.
As far as polishing goes I have no idea how to achieve that using that method could you elaborate as I am new to the trade.
Message 8 of 9
mhzhamza
Thank you Leo,
Let's say I have removed all the stock by using a 3mm ball end mill and an adaptive toolpath, now i have stock remaining only at the vicinity of the razor edge , if I use a 2mm/1.5mm ball end mill can i chain only the V edge excluding the fillet.
Message 9 of 9
mhzhamza
Yes the razor edge is needed , this part is a cutter segment which is mounted on a roller and is used to cut carboard pakckets at the exact some spots where the razor edge is.
