Fusion Manufacture
Creating a high feed tool in Fusion 360.
5 REPLIES 5
marcusCKN2E
129 Views, 5 Replies
Greetings!.
I've been struggling to properly make a tool that resembles the one linked below.
Anyone know how I go about it?
I've been planning to use it for a 3d adaptive clearing, so apparently a form mill won't do..
I've also tried making it a tapered mill (D:50,8, angle:14) but this results in the tool not milling properly.
Also I've tried making it a face mill with the same (D:50,8, angle:14), but that yields the same result as the tapered mill.
Tool:
https://www.iscar.com/eCatalog/item.aspx?cat=3323482&fnum=4182&mapp=ML&app=65&GFSTYP=M&isoD=1
5 REPLIES 5
a.laasW8M6T
in reply to: marcusCKN2E
Normally you need to define it as a Bullnose endmill, and you use a "Programming Radius" value for the corner rad, but for some reason that value isn't listed on the Iscar website for that tool.
This one the Rg value is the "Programming radius"
I use a Taegutec High Feed mill and the Programming radius is written on the back of the packet of inserts so possibly the Iscar one is the same?
marcusCKN2E
in reply to: a.laasW8M6T
Thank you for the response, had no idea that was a thing. I couldn't find any on the packet of inserts.
Since I had no idea programming radius was a thing, I didn't realize it said this on the page of the tool:
How would I go about programming this? @a.laasW8M6T
a.laasW8M6T
Ahh I missed it down there I was looking in the table
So assuming you are using the SOMT, you could set it something like this
The shaft dimensions are only approximate and aren't really critical, more for visals than anything
marcusCKN2E
Thank you!
One more question tho.
With the tool just having a big radius instead of the angle of the tool, does this turn out the correct way still?
seth.madore
For roughing purposes, it turns out "mostly correct". There won't be any gouging of finish surfaces, but there will be small amounts of extra material left in corners. However, since a high-feed-mill is only intended for very course roughing, this shouldn't be too much of an issue for the subsequent semi-finish machining.
Seth Madore
