Creating 2D vector files for CNC
Hello everyone,
I am working on a design for an armoire, and am nearing completion of the design. I plan to build this design using plywood and will be purchasing materials from a local lumber supply store that has a CNC machine. I have determined that it would be easier to have the shop cut slots for the shelves in the sidewalls using their CNC, and I have been corresponding with the guy who does that. After some research, I was able to set up a tool path for what I want to do and I sent the file to the gentleman at the shop. This was his reply:
"Basically I need a 2d vector file
all vectors joined
2 layers profiles and dados
no duplicates
no 3d
call out on depths
Send everything over with plywood type
estimate .725” thickness for ply "
I have been able to glean a decent understanding from the forums of what I think I am supposed to do (what he is asking for), but I am unsure. I think he wants a DFX file of the sketch of the side wall including the slots with dimensions on all of that, and Gcode for the toolpath. Does that make sense?
Thanks in advance!!!!!!
seth.madore
I don't think you will be able to give the shop what they are looking for with Fusion. They are looking for a .dxf file of all the geometry needed, and Fusion can't produce that. We can use a .dxf post processor to produce something close, but it's going to be a .dxf of the toolpath, not part dimensions.
I highly doubt they are going to accept actual toolpath code...
Seth Madore
