Announcements
Create Round 24 RD 1/8 Thread DIN 405
telea_bogdan
Observer
telea_bogdan
Observer
Observer
I want to create this thread : Round 24 RD 1/8
And My problem is whe I want to create tool for this type of thread I don`t find option to select Round Thread  DIN 405, only 60 degree option is available.
Also this standard is not in the option for threading feature in design,
How can I do to have more options to create this thread?
Replies (9)
seth.madore
Are you looking to machine this thread or "just" design it?
Seth Madore
telea_bogdan
Observer
Observer
First I want to designe it and after, machine it, so yes!
a.laasW8M6T
Hi
Creating this thread in design is actually quite difficult, I was able to come up with a very close approximation in the attached file.
You cant get it perfectly round on the top of the thread as that would cause issues with the sweep intersecting.
So I have made the major Diameter 23.99mm instead which leaves a tiny flat.
This isn't really that important anyway as its not a functional part of the thread.
I have to thank Mark @HughesTooling for several examples hes done in the past on how to do it.
I was quite surprised to find that Fusion doesn't have a helical cut type function.
You can program the thread in Fusion, but you cant define the insert correctly so the simulation will be bad, but the code will be correct
Heres an insert from iscar
https://www.iscar.com/eCatalog/item.aspx?cat=5993481&fnum=123&mapp=TH&app=284&GFSTYP=M&isoD=1
telea_bogdan
Observer
Observer
Thank You!
adamF8GLX
Observer
Observer
hello talented fusion people....i too am trying to make a thing (towing eye) with a  DIN405 thread to manufacture.. 16x1/8.. and after hours of searching for ways, trying sweeps and revolves, tracing the darn thing over the drawing of the item i want to make with the thread attached, would anyone be able to point me in the direction of a more experienced how to ?
the 24x1/8 file @a.laasW8M6T  made actually gave me some hope that its possible...im almost at the point of please someone make it and i will pay, but i want to learn.
any help would be awesome
thank you all
a.laasW8M6T
Hi
Do you need to model the thread or do you just need to machine it?
If you just need to cut the thread on a CNC lathe then there is no need to model it in Fusion
you can just Create a threading insert with the correct dimensions and then do a threading cycle on a plain 16.318mm diameter.
the thread insert setup would be like below
The thread parameters would look something like this
resulting sim will not be 100%correct looking because the threading tool in fusion doesn't have the shape to form the thread tops, but it will be fin in real life if you use the correct insert;
adamF8GLX
Observer
Observer
hiya and thank you for the speedy reply ! i do need to model it i think, as i would like to be able to print a test item as i have done with previous things, also i think if i model it it will help me in understanding ways of doing things that may come up in future projects.
i have attached a screen snip of the thread, the top is one an engineer drew on (i have no idea what) but i cant seem to manipulate it/pull it into my sketch and use it, the bottom one is the one i have traced with a fit point spline so i could possibly do something with it.
a.laasW8M6T
Hi
see video on how I modelled it:
adamF8GLX
Observer
Observer
Thank you so much for the reply ! i only just realized it was there. and thank you for taking the time to do the video, so much help !
