Fusion Manufacture
Create a tool from an Onsrud part number
4 REPLIES 4
2319 Views, 4 Replies
I have a specific cutting tool from Onsrud:
40-112
1/4" High Speed Steel Two Flute Downcut for Wood Sheet, Block and Plate A
The product page is here.
I tried very carefully to add all the dimensions, but I'm curious how to (1) share this with my other projects (via cloud library?) and (2) how to get an exact setup/library for this tool?
Thanks for any help for the new guy -- this looks like an amazing tool and I'm interested in investing the time to become proficent.
Tim
4 REPLIES 4
jeff.walters
If you add the tool while in an operation it will be for this part only.
To add tools that can be used in different parts you will need to use the Tool Library.
There is a lot of good information in the CAM help (link below)
http://fusion360.autodesk.com/learning/learning.html?guid=GUIDD4DEC076-DFDD-466B-BEF4-0C5E2BD55583
Jeff Walters
Senior Support Engineer, CAM
in reply to: jeff.walters
Thanks -- that helps. I think I'm going to start a library of cutting tools on github. I surprised no-one has done this.
Your GitHub idea is a good one.
I've been pushing Amana Tool to share an Excel file of their router bit database that can be converted into an AutoCad Fusion 360 Tool Library.
I did find that this is an industry wide problem and hope that Autodesk will join the Generic Tool Catalog ISO 13399 standard and help users easily import tool libraries from various manufacturers. http://gtc-tools.com/
Definitely a Chicken vs Egg issue with the end user bearing the brunt of tedious tool input and frustration.
thanks,
Stephen
Steinwerks
Are folks here aware of the push by some for Adveon integration? It's been talked about on the Autodesk CAM forums as well, but really we're in the dark as to what Tool Library 2.0 will look like in the end.
https://adveontools.com/SitePages/Start.aspx
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
