Crash not showing in simulation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a rouhging path where I use 3d adaptive to clear off stock. I run half of the part and turn in 180 degrees and do the other half with similar paths. I use a copy of the first 3d adaptive operation for the second job and it crashes in the exact same spots on the stepdowns but not on the finishing pass at the "bottom" depth. I run "minimum retraction", 10% stay down level, 0.5mm lift height and 3000mm/min no-engagement feedrate. On lead in/out I have 1mm set on hor/vert lead in/out. I suspect it's related to lead in/out or linking but the error isn't showing in simulation like you can see on the attached picture. I've always trusted simulation before so this thing kinda got me scared since I don't know about crashes like this before they happend.
Down to the right on the picture of the part it shows that the first adaptive operation has 10mm roughing stepdown so the error only apears one time. On the second operation I set roughing stepdown to 7mm and then it hit the part in 3 stepdowns instead of just one from what I can tell.
The machine this code is run on is a 3 axis machine with Fanuc OM-C controller if that matters.
