Correct path for ball end mill
vincentVBT4F
vincentVBT4F
Hi all,
I'm trying to find the best way to achieve inside fillet with a ball-end mill.
The only way I found until now it to make a design without any fillet and do a 2D contour on bottom.
With fillet on the model I can't find a proper way to do it.
Selecting bottom or top of the fillet doesn't give me the wanted result (screen-shot here under)
Fillet radius is equal to the ball-mill radius
Thanks 🙂
ChristopherMarion
Hi @vincentVBT4F
A possible option would be to use the Pencil strategy found in the 3d toolpaths.
If the model has a 1/8" fillet and you use a 1/4" ball, the tool should blend into that radius like you are looking for.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
vincentVBT4F
Thanks a lot !
Pencil with touch surface is working just perfectly 🙂
