It's too early to know how or why or when but I'm editing an old file this morning after an update. All the coolant seems to be defaulted to "OFF". If it's not a problem for you great, but I want y'all to look for this before you go to hogging on some aluminum and break a tool.
I let the guys here know to look out for it too.
Solved by a.laasW8M6T. Go to Solution.
OK....but with what post processor?
Well I hadn't posted the programs yet. This was the coolant toggle in the operation parameters.
You can select what coolant you want to be default and then click on the three dots and save as user default
Your tools in the tool library should have the coolant set already in the presets, so it shouldn't really matter what the default is in the operation
Thanks bro. That wasn't really the point of the post but you did tell me something I didn't know so thank you and "Accept"
