Fusion Manufacture
Convex Dovetail Milling - Is it possible?
3 REPLIES 3
gerrit.agel
139 Views, 3 Replies
Hey guys!
Is it physically possible to mill this shape with a typical dovetail mill?
If not, any suggestions how you would manufacture it?
Thanks!
3 REPLIES 3
seth.madore
in reply to: gerrit.agel
Not with a physical dovetail tool, you'd be gouging the radial face. Turning it would get you much closer, but you'd also have to either create some elaborate fixture to hold it or treat it as a cylinder and then bandsaw the pieces you need.
Seth Madore
matty.fuller
What material and what surface finish required? It could quite obviously be 3D printed in many materials,
gerrit.agel
in reply to: matty.fuller
Unfortunately not, the surface finish needs to be of very high quality, it being a guide. It must allow motion, with as little play as possible. So turning it will be.
