- Mute
- Permalink
- Report
I've got a simple part (https://a360.co/3E0LVuN) that I'm trying to mill from some 1/4-thick G10 material. I have a 1/8-inch flat endmill, and a 60-degree-included-angle chamfer bit. At this point, I feel as if I've tried every possible setting on 2D Adaptive Clearing, 2D Pocket, and 2D Chamfer (using the flat end-mill) to cut the circular groove in the top surface, and everything I can think of in 2D Chamfer (using the chamfer bit) to cut the outer face. Mostly I seem to end up with the dreaded "empty toolpath" error, although sometimes I come up with things that cut away everything EXCEPT the circular groove, or that crash into the outer face and give me a profile that looks like this:
xxx|
xxx\
(i.e., the top bit is vertical, and then there's a chamfer at the bottom).
I've watched several of Lars Anderson's videos, which are very nice, but when I try to do the same things he did, it doesn't seem to work for me.
Can anyone make some suggestions, please, or offer a pointer to somewhere where I could learn a bit more?
