Contour wierd result
HAMMENG
HAMMENG
hey guys,
Got an issue with a contour i'm trying to do. pictures speak a thousand words, so hear's the situation, you can see the contour selected and the resulting tool path. one of the "arms" is shorter than the others. the actual geometry of the profile is the same, but it's not going all the way into just that one for some reason.
if I give it stock to leave of -.001mm it will go into that 4th bit, so it seems it's happy to go straight in and out of the the other 3 but not that one for some reason
LibertyMachine
As I mentioned on FB; Play with the tolerance. If it's already set super tight, open it up. If it's set the opposite, loosen it up. If neither work, could you export and share a sample file?
File > Export > Save to local folder. Return to thread and attach the .f3d
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
