Contour toolpath not changing direction
Hi everyone,
After many tryouts, I am having a problem which seems to be unsolvable. I hope you can support me with this one..
I'm currently working on a simple geometry, an inversed cone, and I am looking to machine only the surface, so following two cicles (a bigger one at Z=0 and a smaller one at Z=-50)
The problematic is that, after asking a contour (or another operation) to perform the desired toolpath, it does not go Clockwisw + counterclockwise for each circle, even if I define correctly the Direction "both ways", but if I set the Direction to be Climb or Conventional, it does indeed work, changing the tool direction from one to another.
How can it be solved? I can seem to find a solution.. Working with a Geodesic operation it works, but I need to work under a regular stepdown and not a stepover...
I have already tried all the Operations but none of them does work, even though it should...
