Announcements
contour is a problem
magpiemachining
magpiemachining
Nothing working here. set up 2 trying to cut the .25 radius. Im not sure what to use. i tried a lot. i cant get the cutter to start past the stock contour either.
seth.madore
So you want it to machine out to these points here? The entire fillet or just one of the passes?
Seth Madore
magpiemachining
Hi Seth there is stock across and i need to start there
magpiemachining
Ive tried 3d pocket parallel horizontal and i couldnt get it to work
seth.madore
Long winded response:
Seth Madore
magpiemachining
Thanx Seth, I see you put some time into explaining this. Thank you. A stock material selection would help here.
