06:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm using a 1/16" bit at a cut rate of 10"/min and lead in/plunge of 15"/min.
I seem to be getting all of these points right where the bit plunges in and out. I'm not sure what I've done wrong. The machine is pretty rigid when it cuts so I'm thinking it might be the way I programmed the cut but could use a hand with how to change it up so i don't end up with these points that I have to sand out. Thanks for any help, as I'm still a noob at CAM in general. Included is the project file and an attached picture of what results in how "contour 8" is run
Fusion
