Fusion Manufacture
continous toolpath in machining operation
1 REPLY 1
shivamrajputwork
103 Views, 1 Reply
i have a query about the tool path in the cam operation in fusion 360.
i am finding difficult to generate the continuous tool path while generating the cam program
the tool path is not continuous due to which the machining time is increasing.
the tool doesn't continue from where it ends the machining process it then again reaches to start point which is increasing the machining time of the part.
kindly help on the above issue as soon as possible. attached image for the reference.
Thank you
1 REPLY 1
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
