On the adaptive tool path it is machining into the component - how can I avoid this ? I have attempted to trim the tool path however this can not be done.
Hi @ryanYANVW,
At what point is it milling into the component.
Can you share your model so I can check.
Is it during a rapid movement?
If so set on the linking tap to allow rapid movement to Always High Feed Mode.
This means you have a dogleg situation on your machine what means that the X and Y axis are not synchronizing and going as quickly as they can to the next position.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
