Confused about toolpaths
inflameWBW5X
inflameWBW5X
So far, I have used fusion about a dozen times to create toolpaths for my cnc router. All of those toolpaths were for items with vertical sides, so just straight forward profile cuts.
This file (Honda logo) I want to cut from 16mm craftwood and is more complicated than the others and I'm at a loss to know what type of toolpath to use and how to set it up.
I have a feeling it's going to be a steep learning curve.
Can I get some help with it please ?
https://a360.co/3dpaAM9
Ketherton21
2d pocket/2d contour/ 3d* parallel
its early. file is exporting
shabbir.abdulhussein
Here's a few resources from the help documentation to help your choice of toolpath selection:
2D toolpaths:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID32D2B912-191D-41E7-81DA-07F6EC4B91A2
3D toolpaths:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID9F9002B3-53E3-4859-A0DE-499D8529DA8C
Once you've decided on a toolpath, you can view its detailed parameters here:
2D toolpaths:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID20E579E7-B808-47D1-BFB2-14056A2B1CFE
3D toolpaths:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID4F934FCC-2283-4429-8C36-F3D11CD917F4
Hope these links help with your learning curve. Don't hesitate to reach out if there's any information you'd like to see more of.
Shabbir Abdulhussein
Content Designer
inflameWBW5X
So, do you mean use 2d pocket for the internal cut outs, 2d contour for the external circumference and 3d* parallel for the sloping shapes ?
Ketherton21
i just grabbed a tool and did the simple toolpaths. you will have to change tools and speeds and feeds accordingly.
inflameWBW5X
Ah ok thanks for that.
I changed things a bit and I think it might work ok with my model.
inflameWBW5X
These are very good links.
Thank you
