Fusion Manufacture
Colors after update?!
6 REPLIES 6
maciej.halas
287 Views, 6 Replies
What happened to selection of geometry contours and stock contours in last update?
Colours are illegible and when I selct geomtry it somehow covers edges beneath it so I have to rotate model to select for example stock.
Why know I go into stock options to see what is selected.
What was the problem with yellow colour for stock and blue for contours? Why it was changed?
6 REPLIES 6
seth.madore
in reply to: maciej.halas
Stock Contours is still yellow though, right? (well, a shade of yellow, closer towards orange)
Seth Madore
@maciej.halas Could you share a recording of the issues you are seeing ? Or some pictures for us to better understand your issue.
Also could you share the path to the following file “gfxtheme.json”. Its roughly here:
C:\Users\pedersr\AppData\Local\Autodesk\webdeploy\production\540c9578410bc15ff261605667cfced82aa9ac6d\Applications\CAM360\Data\gfxtheme\gfxtheme.json
Rasmus Pedersen
Senior Software Engineer
maciej.halas
Hi, I recorded geometry and selection.
Hi @maciej.halas if you have a non-english letter in the path to the file "gfxtheme.json" then its likely CAM-42716.
We are working on a fix for that, though I cant provide an outlook/date.
For now you should be able to workaround this by installing Fusion 360 on a different user account that doesn't contain any non english characters. (Similar to this other user https://forums.autodesk.com/t5/fusion-360-manufacture/problems-with-selecting-chain-after-the-new-up...)
Again I am sorry about but this.
Rasmus Pedersen
maciej.halas
HI, thank you for your reply. I noticed one more thing. On the selected geometry contour I don't see the arrow that indicates the direction of milling.
Hi @maciej.halas if this is on an installation where windows user has non-english characters in the account name that could likely also be a symptom.
If you have another account with only english characters and you still see graphics issues related to MFG selections please let me know and perhaps add a screenshot+video. Also might best to make a separate new forum post for that. We are looking at the forums actively.
Rasmus Pedersen
