Fusion Manufacture
collision with chamber why chaps
1 REPLY 1
107 Views, 1 Reply
never had this problem before.
works fine if relative box size is chosen ,then no extra material.
is it a problem that needs to be fixed in software.
have attached the file.
have both 2d chamber and contour way happens on both
1 REPLY 1
engineguy
in reply to: 830403205
@830403205
Nothing wrong with Fusion that I can see.
This is because the tool is doing an "undercut", it is cutting the excess material on entry which is OK but as there is material above the upper angles at the end of the cut when the tool rises up there is a collision.
Correct, if there is no material there when using a different stock then there will be no collision.
