Fusion Manufacture
Collision Identification Accuracy - Simulation
2 REPLIES 2
richardsalzman
105 Views, 2 Replies
Just curious if I can safely rely on the collision calculations in Fusion.   When I simulated running this part, no collisions were identified.  This did not surprise me as I intentionally made the tool paths work from the outside of the part towards the inside.   I was just wondering if the cutter details are accurately input into Fusion, are the Fusion calculations accurate or just intended to be used as a guide?  I had originally ordered a longer endmill, then realized I could possibly use my shorter one.
Thanks... Richard
2 REPLIES 2
it'll be as accurate as the information you input
Please click "Accept Solution" if what I wrote solved your issue!
Thanks!
