Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
CNC Turning Custom Machine Kinematics
3 REPLIES 3
prithwiraj_93
304 Views, 3 Replies
Hello alll,
I am trying to make a custom machine in Fusion 360, I am having a hard time understanding the kinematics and how it should be set up for my machine.
My Machine is a simple CNC Lathe with an 8 tool turret, Its Z axis is along the spindle and X is perpendicular to the spindle.
Can someone suggest what the kinematics will be? A Screen Shot will be much appreciated if possible.
Labels (3)
3 REPLIES 3
seth.madore
in reply to: prithwiraj_93
All you really need is this:
That said, there's no inherent benefit to having a machine config at this point in time for any lathe. Machine Simulation doesn't work with lathes, so that's a non-starter. However, having a machine config does make it easier to post out code as you iterate thru any changes you want to make.
Seth Madore
seth.madore
Hmm....that's incorrect, I think. I'm trying to copy what I've done for my Lynx and I can't get the Main Spindle to allow for an RPM range 🤔
Seth Madore
prithwiraj_93
in reply to: seth.madore
I think this worked for me, so far I have not found any issues. Thankyou so much.
Technology Administrators
