Fusion Manufacture
CNC Tool runs into other features
2 REPLIES 2
mattkcv
97 Views, 2 Replies
Hey all, I'm quite new to the cam side of things. I'm currently stuck on a particular feature in the screenshot below.
I spent the majority of Friday researching, and I cannot get the cut-out on fin 5 to be machined without the tool hitting the adjacent fins. Using the 2D pocket causes the collisions.
I've also tried the 3D contour, with the avoid selection option, and it gives me an empty toolpath error. I'm using a 3/8" flat endmill and would prefer to keep it that way to avoid tool changes, but it can be changed if need be.
Also, if anyone has any suggestion about how to machine out the cut-out of the lower/front left corner, that'd be great. I can get it cutout, but that was by using a 2D contour along the entire left face, which I'd rather not do.
Attached are the files, Blank Heatsink is the stock form, Heatsink 20A is the desired result.
Matt
2 REPLIES 2
seth.madore
in reply to: mattkcv
You're going to want a 2D Contour toolpath with just a little bit of Tangential Extension along with "Roughing Passes":
For your second question, just use the ALT key and force 2D Contour selection into an "open" strategy:
File is attached for your review
Seth Madore
mattkcv
in reply to: seth.madore
Hey Seth, thanks a ton, that is exactly what I was trying to do.
