Announcements
CNC Profile Cutting Kjellberg PerCut2000
jmmNLUG8
Observer
jmmNLUG8
Observer
Observer
Hi All,
We have recently moved from Fastcam9 to Fusion and we are trying to get our CNC Profile cutter set up in Fusion. Has anyone else used Fusion with a Klejjberg CNC Profile Cutting Machine? If so, would anyone be able to help us  get set up?
Thankyou in advance
Replies (7)
seth.madore
Since you've been using another CAM program, that would suggest that you have some NC programs to share with us so we can point you in the right direction; could you share those sample programs here?
They do need to have a .txt or .nc extension, so you may need to rename the extension to share it here.
Seth Madore
jmmNLUG8
Observer
Observer
Thanks Seth,
I have attached a couple of CNC files that we have recently cut on our plasma, is this what you were after?
jmmNLUG8
Observer
Observer
Hi Seth,
Did you have a chance to have a look at the files?
Thankyou
seth.madore
I apologize, I've been in Chicago all week for the IMTS show. Looking at your output code, it doesn't seem to be too complex and we should be able to get you close with one of our existing waterjet/laser/plasma posts.
That said, I do have some questions about the following M and G codes:
M95 T1
G71
G91
M29 T1
If you could give us some further info for these codes, that would help point us in the right direction!
Seth Madore
jmmNLUG8
Observer
Observer
Thanks Seth,
I have attached some codes from the brand of machine
jmmNLUG8
Observer
Observer
I am wondering if you were able to help?
jmmNLUG8
Observer
Observer
See attached
