Announcements
CNC NOT RETURNING TO HOME
CasettaMichael
CasettaMichael
Today my assistant sent a code and the cnc operator told me the machine did not return to home... this is our model https://a360.co/2MnDTWH.. i could not figure out what went wrong with this file... anyone know what's wrong?
daniel_lyall
What machine is this for?
Can you attach the Gcode?
What postprocessor are you using, if it is an edited one can you post that as well?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
CasettaMichael
We use a scorpion ez-router. Enclosed is the g-code. We do not alter the code or use a post processor. Thanks for responding -mike
CasettaMichael
i spoke with  cnc, we went over a few codes  He showed me on my files where to look to see it returning home. The codes i wrote today returned home, the ones written by my offsite assistant did not show this command line .  The question is what setting was thrown in fusion to cause this to happen.?
daniel_lyall
How do you generate the Gcode from fusion?
Daniel Lyall
The Big Boss
Mach3 User
CasettaMichael
we resolved the issue. My assistant did not have the post processer configured. thank you for your time
