Hi I am trying your Fusion 360 as a replacement to my Mecsoft Rhino cam. However I do not see CNC masters Jr listed ? My book tells me it works with FANUC g-code. Please advise.
Harry
Hi @Anonymous,
Thanks for raising your query onto Autodesk forum.
As you mentioned that your machine works with Fanuc g-code then I will suggest you to try using the Post processor "Fanuc.cps" as shown in the image and see if you can run your machine with the G-code output with this post.
Note: I will suggest you to run the machine in air under total safe condition while initial trial to test this post.
Also like to inform you that we have a Post processor library which has many additional post processors which are not included in the default Post. You can visit the Post Library for Autodesk Fusion 360 here.
If you need any further help with the Post processor then I will suggest you to visit our HSM Post Processor Forum.
I hope this helps.
Thanks and Regards,
