Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
CNC 2D Contour Cutting into part
4 REPLIES 4
moderndesigns9
348 Views, 4 Replies
using 2D Contour with 1/6" endmill
The simulation is showing it will cut into the part, what is the reason for this?Screen Shot 2021-10-29 at 4.26.43 PM.png
4 REPLIES 4
It wants to more details please
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
What is the compensation type set to? Looks like it might be off. If it's not this can you export your design as an f3d and attach?
Mark Hughes
Owner, Hughes Tooling
contour tab, then click the red arrow by your geometry. You're choosing the wrong side of the line.
Please click "Accept Solution" if what I wrote solved your issue!
Looks to be centre cutting to me. Note the green stock is cut either side of the edge and the lead is from the outside. The blue toolpaths are on the edge of the part as well.
Mark Hughes
Technology Administrators
