Cloud posts not syncing with team
Billy.conturo
Billy.conturo
I'm having some issues with this. From reading some other related posts I don't think I'm the only one. I tried a full restart of the system. My entire team is having this issue.
cloud not syncing up
Replies (37)
kencondal
Hi Jeff,
Here are the two most recent logs.
I still don't know how to execute the rescan command you mentioned.
Ken
Billy.conturo
I'm not sure how to enter text commands in fusion. Is there a quick guide to doing that?
jeff.pek
In the File dropdown, there's a View submenu. In that, you'll see "Show Text Commands". You can type in the text command in the lower (small) text area.
  Jeff
jeff.pek
Thanks. I see other errors on your log, aside from the problem with the diagnostic logs.
Can you confirm that you have sufficient disk space on the drive that contains %localappdata%, and that you are able to create files in that area (manually)?
Jeff
kencondal
Jeff,
The drive has over 64 GB of free space and yes, I just created a file there.
Is one of the other errors that Fusion keeps downloading the same update? I've gotten the May update at least 3 times and the June update twice (the second of which should be in those logs).
Ken
Billy.conturo
I entered that command and now things seem to be updating on my machine. Will it stay that way or do I need to run it every time I want things to sync? When I run the command on a different machine I get this error
Traceback (most recent call last):
File "<string>", line 1, in <module>
NameError: name 'wipmds' is not defined
jeff.pek
Hmmm. Might be worth posting specific posts about those problems in the Support forum, where others can hopefully chime in?
  Jeff
balsmen
Hey @Billy.conturo,
In the text command panel on the computer you saw the problem for, on the bottom right of the panel you should see 3 radio buttons - one for "Txt", one for "Py", and one for "Js".
In order to run this specific text command, you need to make sure to have "Txt" enabled.
Noah
Noah Balsmeyer
Fusion Mfg Software Engineer
Billy.conturo
Ah yes, of course. Sorry about that. I'm running around doing a thousand things today.
Billy.conturo
@jeff.pek
Actually, the dropdown dialogue in the post config still isn't realizing I deleted files from the CAMposts assets. The text command seemed to have no effect.
Billy.conturo
 to produce the problem:
close fusion
delete cache
delete contents of CAMposts assets folder in browser
open fusion
no posts in config dropdown
close fusion
upload a few posts in browser to CAMposts
open fusion
cache is created
posts listed in config dropdown
close fusion
delete all posts again for CAMposts assets folder in browser only
open fusion
posts still listed in config dropdown  <--- cache didn't update
So we are back where we started. To consolidate things I reposted my issue in this message with the step by step to produce the problem.
jeff.pek
And, with this, running the "rescan" command still didn't help?
Can you send me a recent log file?
Thanks. I hope we're able to get to the bottom of this, and get a fix going.
Jeff
Billy.conturo
correct, rescan didn't seem to do anything.
kencondal
This bug just keeps getting worse! Now when I upload a CAM post to replace an existing one (same name) Fusion is still executing the old one. The list of CAM posts I'm seeing doesn't match what's in the Assets Folder - some are missing and others that were deleted days ago are still there.
I've reset my cache and run rescan and nothing seems to help.
Ken
kencondal
After seeing these missing cloud posts on my two Win 10 machines, I just tried it on my MacBook Pro and it reports no cloud posts (there should be 4 of them). Everything else in the cloud - templates, tool libraries and projects are all fine. The assets folder and the web interface all list the posts but the CAM section doesn't see them or sees the wrong ones.
I really hope this gets fixed in the next release.
Billy.conturo
I see the newest update fixed the syncing issue. Fantastic!!!
kencondal
This is NOT solved with the latest update.
I'm still having the same problem with the CAM not seeing the correct cloud posts. I have 3 machines - 2 Win 10 and one MacBook. They all see different things in the cloud library and none of them are correct.
Billy.conturo
Ya, I spoke too soon. It seemed to be working at first but now it's not. I'm going to have to put our posts on a google drive for now until it's worked out.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
