Change Toolpath Direcection
alan
alan
I would like the toolpath direction to be changed by 90 degrees in a contour operation.  I think I found a setting in the past but can not remember what it was.  Please help.
Thank you.
Replies (8)
seth.madore
Are you talking about a start point or something else? A visual of what you are referring to would be very helpful
Seth Madore
alan
Seth,
Sorry for the delay in answering I was traveling.  Not the starting point.  Say the cutting direction is following the X axis back and forth but I want it to follow the Y axis back and forth.  Most parts Fusion picks the correct direction but occasionally I want to go the other way.
Any suggestions?
Thanks Alan.
s.noke71
Passes tab, pass direction change to 90 deg for instance
alan
Thank you.  I must be missing something.  In the passes tab I see a "Direction" box but I can only select "climb" "conventional or "both ways".
Any ideas?
s.noke71
no pass direction? up a little from direction? what tool path is it you may have to turn on finishing
alan
It is a 3D contour.  I think I have seen what you are describing in the past that is why I have asked on this forum.
s.noke71
No i dont thin 3d contour has the option, can you change to a parallel operation its a bit more flexable?
alan
Perfect!  Thank You!!  I knew it was there.
