Fusion Manufacture
Change One surface recalc everthing
3 REPLIES 3
Bnuno608
190 Views, 3 Replies
Im new in manufacture, Im struling with this:
Everytime i add a surface to help me on strategy, or protec
All toolpaths start updating, i know i can protect
But then i unprotect to Change some thing and recalc again. Is this the right method?
Another question, i aplied One surface to cover a hole.
Made some toolpath
How i want to remove that CAP hole
I cant calc anymore, says setup miss a surface.
How can i make to ignore a surface protection without deleting
3 REPLIES 3
HughesTooling
in reply to: Bnuno608
Do not add the cap to the setup, just add it in the op under Model. This might help with the other problem you describe, only select the main body (don't select a component) in the setup then add any helper surfaces only in the actual operation that needs them.
Mark Hughes
Owner, Hughes Tooling
Bnuno608
thats great,
the rule here is to only choose in setup a clean model i want to machine without surfaces protection
then, evertime i need a protec surfaces, just create a new and make sure that is not in setup.
in toolpath select "model" and choose a surfaces i want to use has protection.
right?
seth.madore
@Bnuno608 wrote:
thats great,
right?
More or less, yes. There are some instances where you may want to include some extra surfaces in your Setup, but it does require some foresight into the long term project at hand. In general, surfaces are better leveraged at the toolpath level itself.
Seth Madore
