Change direction from Y to X
gijsYVNPU
gijsYVNPU
Dear forum,
This is my firts post here, so thanx in advance for any help.
Shortly i will receive an Onfintity Foreman with a 2.2 KW Spindle from PWCNC.
I already made my first project in Fusion 360.
In this project i like to cut some grooves, but I can not seem to get the direction right. In the setup now it takes way to long wich is inmy opinion not neccesary.
I am looking for "direction" in the passes tab but can't seem to find it.
I am using a 2D adaptive strategy for this operation.
Any thoughts?
programming2C78B
thats how adaptive works, always. If you want to slot through it, you'll have to just do 2D contour and cut full width.
Please click "Accept Solution" if what I wrote solved your issue!
gijsYVNPU
Thanx! that did the trick.
