Fusion Manufacture
Change automatic view whenswitching from set up to set up.
2 REPLIES 2
jscott6SWZG
128 Views, 2 Replies
Sometime ago when you switched from one set up to another (with the same model) say flip over from top to bottom.  The model stayed in the orientation.  You then had to re orient the part to get see the side you were working on top.
Now when you flip the part fusion automatically rotates the part.
How can I get back so I have to manually flip the part.   I find this helps me ascertain exactly how the part has to be flipped in reality.
2 REPLIES 2
seth.madore
in reply to: jscott6SWZG
"Sync View"
Seth Madore
jscott6SWZG
AAAAh sweet  Thanks I should have asked three months ago.
