Announcements
Chamfer tool set up
Chamfer tool set up
I am not certain which dimensions are dropped into each tool criteria.  This results in chamfers that don't look good.  Could you please help me set up one chamfer tool.  I can't find an example on youtube   tool diameter is .25"
LibertyMachine
The beauty of 90 degree chamfer tools: The length of cut is always half the diameter, assuming the tool comes to a point and not a large flat.
So, setup your tool like this:
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
thank you.
Ah, the cutter distance was messing me up.  Used your information to work it backwards. Thank you so much.
http://www.1728.org/angsize.htm
