Fusion Manufacture
Chamfer on slope
4 REPLIES 4
scotS3G9D
153 Views, 4 Replies
Chamfer on slope
I have some parts that have a chamfer on an edge that slopes downwards.  In the past, I've used a 3d toolpath but it can be tricky for someone like me (inexperienced) to program, takes a long time to machine, etc.  Is there a way to use a chamfer tool path for something like this?  Please see the attached pic and model file.  I only have a 3 axis machine and a standard Fusion account, no machining extensions.
Thanks, Scot
4 REPLIES 4
marcus.toepke
in reply to: scotS3G9D
You can try the operation - Projection
or the Deburring operation (I mean this is extension)
scotS3G9D
Thank you, Marcus.  The trace projection will be fine...looks very nice.  Is there a way to make the chamfer go all the way in towards the round center of the part?  I cannot figure out how you have made the projected selection.  Can you help me understand?
I thought maybe you created a sketch and selected a projection but I see no sketch.  I tried to create a sketch myself but the projection does not follow the slope/curve of the part.
marcus.toepke
So I first created a production model
I then created a copy in the production model, but be careful with "paste new"!
then I removed the bevel from the newly inserted model
I could now select the contour on this model
The problem of machining the chamfer right up to the cylinder is of a different calibre!
From a purely physical point of view, this is quite difficult, as there is always the threat of driving the tool into the cylinder.
However, you can play with the values, depending on your tool dimensions, in the operation to get closer to your cylinder...
Change the chamfer values
and then change the lead in / lead out values
with this changes values you can get closer
scotS3G9D
Thank you for your help, Marcus!  It takes some adjustments, but it works great.
